V4 4500 183MHz BIOS - testers wanted
Area for international users
Hi visitor, I have created a 183MHz BIOS for v4 and I'm looking for testers.
Its based on v1.15 and it changes the dram latency from 2-2-2-6 to 2-2-3-6.
Files and documents are available here: http://download.pc-centrum.net/V4_BIOS_rev.3.zip
mod edit: grammar :wink:
FOR TESTERS please write here:
1)Stable on my card YES/NO
2)Performace before/after
3)Tempeature
4)Brand of memory
5) (optional) what you mean about my anty-nVidiot logo :lol:
sorry for my gramar :oops:
Naposledy upravil(a) -HoNY- dne pon srp 22, 2005 4:37 pm, celkem upraveno 2 x.
I.C.
Re: V4 4500 183MHz BIOS - testers wanted
Příspěvek od I.C. »
I have two spare boards and will try each, AGP right?
I.C. píše:I have two spare boards and will try each, AGP right?
Yes its AGP bios.
Whats BRAND of memory on card?
I.C.
Příspěvek od I.C. »
One Toshiba, the other Hyundai
I.C.
Příspěvek od I.C. »
Both 4500's have been flashed and are running Quake 3 demoloops at 183 mhz.
3DMark2000 fill rate MTexel/s before : 271/323
3DMark2000 fill rate MTexel/s after: 290/355
Quake 3 before: 32.0
Quake 3 after: 35.2
1024 x 768 x 16bit x 2x AA, demo 001.
The back of the GPU is very warm under full load, 141-145F.
I will check later today what the temp is at default clock of 166.
Nightbird
Příspěvek od Nightbird »
@ -HoNY-
Some people try to modify a V4 4500 32 mb into 64 mb (an old dream now) ; i have No idea if they can or will succeed but the current bios will be perhaps a "botleneck".
What do you think about that ?
..you mean that voodoo4 4500agp 64mb that was created by DenisF? I think he created his own bios (so the card was able to "see" the additional memory),are you suggesting HoNY should mod that bios as well?
I.C.
Příspěvek od I.C. »
ps47 píše:so the card was able to "see" the additional memory
Jindra Semenec states it is not a bios issue but a hardware one.
Bios changes will make no difference, the card still will not access the extra ram.
..according to this,the v4 4500agp 64mb mod is complete and fully working..
I.C.
Příspěvek od I.C. »
And what proof does this individual offer? A picture that can be done in Photoshop?
"no amount of bios mods will let the board see the extra ram modules"
You can put your trust in Jindra Semenec, patron saint of VSA-100 or a 17 year old who posts on web forums.
Nightbird
ps47 píše:..you mean that voodoo4 4500agp 64mb that was created by DenisF? I think he created his own bios (so the card was able to "see" the additional memory),are you suggesting HoNY should mod that bios as well?
I thought indeed about this V4 4500 but also a topic on VoodooAlert.de.
According that, you would need a (new) resistor on the pcb in order that the board utilizes the new ram.
But probably you would need then to modify the bios.
I.C. píše:Both 4500's have been flashed and are running Quake 3 demoloops at 183 mhz....
My cooler mod 8-) with spire[url=IIhttp://www.spire-coolers.com/fcc.asp?ProdID=41]RackSpearII[/url]
Nightbird píše:@ -HoNY-
i wanted ram for this mod (5 or 5,5ns SDRAM) is better for agresive latency ;-) my dream is V4 4500 64MB @183 2-2-2-6
I.C.
Příspěvek od I.C. »
Nice but only helps one side of GPU ;-)
I have mod for cooling backside, will post picture soon.
Jindra Semenec states PCB of card dissipates up to 50% of heat generated.
I.C. píše:Nice but only helps one side of GPU ;-)
my card is cold cca 35°C = ???F :?
T(F) = 1,8 × T(C) + 32
I.C.
Příspěvek od I.C. »
140 degree Fahrenheit = 60 degree Celsius
http://www.onlineconversion.com/temperature.htm
What is the reading on the backside of the card where the GPU pad is located? And what are you using to test?
I have used digital probes from Radio Shack but have just started using infrared meter.
I.C. píše:140 degree Fahrenheit = 60 degree Celsius
thanks :oops:
I.C. píše:What is the reading on the backside of the card where the GPU pad is located? And what are you using to test?
My hand is qualyty tempeature-metr 8-) :lol: on backside where is GPU
I using FAN on cooper heatsinks therefore is too small tempeature ;-)
obrázek vložen na požádání...
I.C.
Příspěvek od I.C. »
Thanks for posting picture! :D
20F-25F temp drop at rear center of GPU when fan is running while under maximum load.
nice one 8-)
