Videli jste nekdy Geforce4 ve SLI ?
Ventana 4210
Ventana 5120
Ventana 7135
Ta je ovsem postavena na NV35.
Obrazky jsem nasel na strankach http://www.quantum3d.com kde je mimochodem spousta zajimavych veci.
Ale to vsichni jiz jiste vite
Quantum3D Ventana
Quantum3D Ventana
Jindra Semenec
Jindra Semenec
jj Quantum3D - samé prekvapko čo je ale zase toto ?:
Quantum3D does indeed make some Arcade equipment, this videocard is based on a 3DFX Voodoo Banshee, whats the difference bewteen this and a normal Voodoo Banshee?? Notice the two ports on the picture, one port is a VGA connector (for VGA monitors) the other is a 9pin EGA connector (for 15kzh/24khz arcade monitors).
You flash the BIOS to what arcade monitor you want to interface, either 15khz (CGA) or 24khz (EGA), the VGA output is never changed.
To achive the output to lower resolution monitors the AArdvark does anti-aliasing, a simple two-by-two anti-aliasing scheme to compress the 2D into a low-resolution display format.
15khz the output is 320x240, and supports either 320x240 or 640x480.
24khz the output is 512x384, and supports either 512x384, 800x600, 1024x768.
The VGA screen must be one of the above modes and running at 60hz for the video output to be correct.
As the card is almost identical to the Banshee/Voodoo3 in DOS, all references to extra Aardvark functions our noted.
Voodoo Banshee/Voodoo3
All Voodoo boards from Banshee to Voodoo3500, both AGP and PCI.
Advantages
* Full MAME support for 15/24khz games (using VSyncMAME).
* Native 15/24khz output (Aardvark only)
* No need for a VGA monitor, PLUG AND PLAY. (Aardvark only)
* Windows and Direct3D/OpenGL/Glide at 15khz or 24khz. (Aardvark only)
* Motion Compensation for DVD playback.
* 3DFX Glide support.
* Simulatanous VGA and Arcade monitor output (Aardvark only).
* Banshee/Voodoo3 2000 cheap.
* Supported by Mon-ARC! (full DOS TSR solution)
* In-Future support from WinMon-ARC! (25khz Medium Resolution monitor Windows95/98 driver)
Disadvantages
* Vesa1.2 when in native arcade mode (Aadvark only), VESA3.0 in software mode.
* Native 15khz output is awful, too blurry (Aardvark only).
* RGB settings on Arcade monitor way off in Native mode (Aardvark only).
* No interlace mode (requried for Vector games).
* Expensive if Quantum3D Aardvark..
I honestly recommend a Voodoo3/Banshee card and nope I don't work for 3DFX.
Advantages
Disadvantages
