Incubation Remake?
Incubation Remake?
vyzera to tak ze rusaci idu spravit remake 3dfx pecky Incubation.blizsie detaily snad oznami niekto kto vie po rusky
hlavna vyhoda spocivala v podpore D3D,ale glide wrappery odvtedy urazily kus cesty (incubation uz bezi na non-3dfx kartach takmer bez chyb) takze to de facto stratilo vyznam..
edit: vzdy ma prekvapi aka je ta hra chytlava-v utorok som to nakopol v robote a posledne tri dni ma to nepustilo
ak by mal niekto tiez zaujem: http://rapidshare.com/files/35676523/inctwm.rar
heslo je turnbasedtactics4ever.je to moj vlastny rip,komplet hra aj s datadiskom,plne patchnuta a plne funkcna,prec je len hudba (a nanestastie zvuk z ingame animaciek,ale tie sa aj tak vzdy iba skipuju),malo by to bezat na uplne hocicom co len trocha podporuje 3d akceleraciu..pozor,prilozene wrappery su len v zakladnom nastaveni,takze ak to chce niekto spustit v okne pripadne hi-res tak bude musiet nainstalovat prislusny vrapper kompletne a nastavit to vlastnorucne..a pokial chcete mat bezchybnu grafiku,treba nastavit desktop na 16bit
full readme (included in the rar):
welcome.
this is a rip of Incubation: The Wilderness Missions english version,fully patched.
unlike the first one,its quite user friendly,all you have to do is launch the correct *.bat file,and the game will be optimized for your graphics card.no more special fixes and patches.
how to install:
1)unzip to a folder of your choice
2)run incubation.reg,click yes if prompted
3)if you have win2000/xp,set the compatibility mode to win9x on both ITWM_HW.exe and ITWM_SW.exe
now the game needs to be optimized for your graphics card:
-if you have a voodoo1/2/rush card installed,simply run ITWM_HW.exe,this will launch the game in hardware mode.
-if you have a voodoo3/4/5/velocity/banshee card,run !3dfx.bat,this will optimize the game for newer 3dfx cards (you dont have to run the bat every time you wat to play,one time is enough,once the optimization process is completed,its not necessary to repeat it).you can now play the game in hardware mode by running ITWM_HW.exe.
-if you have a old DX7 card (nvidia tnt/tnt2,ati rage,intel extreme graphics and similar),run !dx7.bat,this will optimize the game for old DX7 cards (you dont have to run the bat every time you wat to play,one time is enough,once the optimization process is completed,its not necessary to repeat it).you can now play the game in hardware mode by running ITWM_HW.exe.
-if you have a modern DX8/9 card (nvidia geforce and ati radeon),run !dx8_9.bat,this will optimize the game for new DX8/9 cards (you dont have to run the bat every time you wat to play,one time is enough,once the optimization process is completed,its not necessary to repeat it).you can now play the game in hardware mode by running ITWM_HW.exe.
if you need more info or help,check http://s2.invisionfree.com/Incubation_F ... owtopic=53
this line is missing from the readme: running incubation.exe will launch Incubation: Time is Running Out. dont forget to run the exe in win9x compatibility mode if you are using win2000/xp.
